Introduction
Replace the func. set turn dial of the Canon PowerShot SX50 HS.
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
Remove the four Phillips #000 screws, length 3 mm, attaching the metal panel to the inside of the back encasement.
2 other people completed this guide.
2 Comments
Interested to know where I can buy the switch/ribbon assembly for that function dial?
I appreciated the clear instructions and photos. Couldn’t be any better. Now I would like to know where to purchase the dial assembly.
