Pull the back panel away from the camera body, starting at the end with the function buttons.
Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Push the metal frame away from the metal tab using the spudger to detach the frame.
Rotate the metal frame upwards.
Carefully lift the metal frame from the camera.
Remove the black LCD screen, leaving the thin lens pieces in place.
Carefully pull on the orange connector ribbon to disconnect the LCD screen.
The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
Using the spudger remove the shutter button by prying the small tab on the front side of the camera.
With a spudger disconnect the orange connector ribbon as shown.
Disconnect the orange connector ribbon that is located under the now removed shutter button.
Remove the screws shown. Start with the outside 6 (3-2.90mm & 3-2.40mm) screws on the metal frame. Then remove the 6 (2.40mm) screws on the back of the lens piece
Detach the mother board with lens from body of camera.
Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
Your lens has been removed from the motherboard and bottom framing.
