Canon PowerShot S400 LCD Screen Replacement
  1. Canon PowerShot S400 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Canon PowerShot S400 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
    • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
    • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Remove the four 4.75 mm screws that sit at the bottom of the camera.
  2. Canon PowerShot S400 LCD Screen Replacement: step 2, image 1 of 1
    • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
  3. Canon PowerShot S400 LCD Screen Replacement: step 3, image 1 of 3 Canon PowerShot S400 LCD Screen Replacement: step 3, image 2 of 3 Canon PowerShot S400 LCD Screen Replacement: step 3, image 3 of 3
    • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
    • Remove the two small metal plates, which the four screws held in place.
  4. Canon PowerShot S400 LCD Screen Replacement: step 4, image 1 of 2 Canon PowerShot S400 LCD Screen Replacement: step 4, image 2 of 2
    • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
    • Remove the small black plastic piece and set it aside.
    • If necessary, use tweezers to remove the small black plastic piece.
    • Detach the front case and back case.
  5. Canon PowerShot S400 LCD Screen Replacement: step 5, image 1 of 1
    • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
    • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
    • In the image, we have already removed some of the screws.
  6. Canon PowerShot S400 LCD Screen Replacement: step 6, image 1 of 3 Canon PowerShot S400 LCD Screen Replacement: step 6, image 2 of 3 Canon PowerShot S400 LCD Screen Replacement: step 6, image 3 of 3
    • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
    • Gently release the black latch.
    • Remove the ribbon cable and metal plate assembly.
  7. Canon PowerShot S400 LCD Screen Replacement: step 7, image 1 of 2 Canon PowerShot S400 LCD Screen Replacement: step 7, image 2 of 2
    • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
    • Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • Gently detach the ribbon cable.
  8. Canon PowerShot S400 LCD Screen Replacement: step 8, image 1 of 1
    • Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
  9. Canon PowerShot S400 LCD Screen Replacement: step 9, image 1 of 2 Canon PowerShot S400 LCD Screen Replacement: step 9, image 2 of 2
    • Remove the LCD screen and set it aside.
Ross Bryan
359 Reputation
3 Guides authored
Cal Poly, Team 5-19, Amido Winter 2011 Member of Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 3,057
