Introduction
Replacing the LCD Display should be done when the display has been damaged or it has been determined that the LCD is no longer functioning. This will take some time. Handle the display with care once you reach the component as it is attached to several other vital components.
Parts
No parts specified.
  1. Place thumb on area right next to where it says open and slide to the right to open.
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Remove the battery by pushing the orange object outwards; the battery will spring up and out.
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Place the camera on to the side that has the image stabilizer label. Remove the 5.00 mm screws that are on this side using the screwdriver.
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Place camera on to the side with the A/V Out Digital Cover facing up.
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Remove the 5.00 mm screw from behind the cover.
    • Remove the 5.00 mm screw from behind the cover.
  7. Make sure the battery cover is open.
    • Make sure the battery cover is open.
  8. Turn the camera onto the side with the A/V out Digital cover. Use your finger to pull this tab to the right.
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Remove the lens side by using your fingers or a spudger to pry it gently open. Try to pry it loose all around that side so that it is easier to pull off. Try to pry it loose all around that side so that it is easier to pull off.
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Using your fingers, pull the screen side gently off. Try to loosen it all around that side so that it is easier to try and pull it off. Try to loosen it all around that side so that it is easier to try and pull it off.
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
  11. Remove the three 5 mm screws Remove the three 5 mm screws Remove the three 5 mm screws
    • Remove the three 5 mm screws
  12. Pull the screen away from the main components. Do not pull hard as there are some ribbons still attached to the motherboard that could be damaged if you use too much force. Do not pull hard as there are some ribbons still attached to the motherboard that could be damaged if you use too much force.
    • Pull the screen away from the main components.
    • Do not pull hard as there are some ribbons still attached to the motherboard that could be damaged if you use too much force.
  13. Lift the metal plate with the plastic opening tool. Lift the metal plate with the plastic opening tool.
    • Lift the metal plate with the plastic opening tool.
  14. Remove all of these 5 mm screws
    • Remove all of these 5 mm screws
  15. Gently remove the lens componenet. The orange flex cables are connected to ZIF connectors. Be sure to disconnect and reconnect them properly by first unlocking the retaining flap on each connector. The orange flex cables are connected to ZIF connectors. Be sure to disconnect and reconnect them properly by first unlocking the retaining flap on each connector.
    • Gently remove the lens componenet.
    • The orange flex cables are connected to ZIF connectors. Be sure to disconnect and reconnect them properly by first unlocking the retaining flap on each connector.
  16. Detach the Motherboard, and then gently pull the motherboard away from the screen. Detach the Motherboard, and then gently pull the motherboard away from the screen. Detach the Motherboard, and then gently pull the motherboard away from the screen.
    • Detach the Motherboard, and then gently pull the motherboard away from the screen.
Matt Mullins
104 Reputation
1 Guide authored
USF Tampa, Team 1-1, Sullivan Spring 2014 Member of USF Tampa, Team 1-1, Sullivan Spring 2014
USFT-SULLIVAN-S14S1G1
1 Member
1 Guide authored
One Comment
useless if you try to do it reverse.. Don't even try it.
The Heat - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 404
