Canon EOS Rebel XS Interior Eyepiece Replacement
  1. Canon EOS Rebel XS Interior Eyepiece Replacement, Latch Side Cover: step 1, image 1 of 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Interior Eyepiece Replacement: step 2, image 1 of 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Interior Eyepiece Replacement, Disassembling Canon EOS Rebel XS Front Cover: step 3, image 1 of 1
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Interior Eyepiece Replacement: step 4, image 1 of 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Interior Eyepiece Replacement, Back Cover: step 5, image 1 of 1
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  6. Canon EOS Rebel XS Interior Eyepiece Replacement: step 6, image 1 of 1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  7. Canon EOS Rebel XS Interior Eyepiece Replacement, Top Panel: step 7, image 1 of 1
    • Remove the following ribbons with the tweezers by gently pulling on them.
    • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
  8. Canon EOS Rebel XS Interior Eyepiece Replacement: step 8, image 1 of 1
    • Remove the cable heads attached on the front side of the camera next to the lens mount.
    • Be gentle when puling wires lose, use the tweezers to remove the wires.
  9. Canon EOS Rebel XS Interior Eyepiece Replacement: step 9, image 1 of 1
    • You can use your fingers to pull the top panel of the camera.
  10. Canon EOS Rebel XS Interior Eyepiece Replacement, Interior Eyepiece: step 10, image 1 of 1
    • After removing the top panel, you can use your fingers to remove the eye piece from the camera.
Daniel Bussone
1,251 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
21 Guides authored
2 Comments
Is there a part number to order the interior eyepiece? It does me no good to take it apart if I don't have or can't find a replacement for it.
Erik - Reply
How do you replace the internal battery?
rideswchrist - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 7,113
