Introduction
If you have experienced an issue with a bent CF pin or non functioning card reader, this guide shows how to replace the card reader. The part is approximately $30 on eBay US.
Let me first start out with a precaution:
This is a challenging repair. I would advise against it if you don't have repair experience, especially since it's an expensive camera.
However, if you are ambitious DO NOT LET THAT DISCOURAGE YOU. If you have done repairs before (replaced iPhone screen, built a computer etc) you will be fine. Just take your time and be patient. If you have an issue or cant understand my guide, please comment asking for help and I will be happy to explain
First the outside screws need to be taken off. Start with the three screws on the left of the camera (looking from the back).
To get to these screws, the front rubber pieces will need to be removed. Run a plastic opener under the edge, and peel the rest off.
Once the rubber is off, remove the top two screws pictured
Once the top two are removed, the bottom one must be removed.
Open the port covers to gain access to the screw, and remove it.
The top 4 screws need to be removed next. They are located behind the eyepiece.
Remove the eyepiece by squeezing the sides and pulling up
Once it's removed, you will be able to see the 4 screws.
Remove these 4 in any order
The final screw securing the back of the camera is located under the thumb grip rubber. Using the same process, peel back the rubber starting from the top.
The entire piece does not need to be removed, just enough to reveal the final screw well
Once access is gained to the final screw remove it.
To remove the connecting flex cable, something can be used to hold it up (CF card was used in the example photo), or simply hold it up with another hand
Use a plastic opener to pry the bottom connector out of the socket.
Once disconnected, lift up the back and set it aside, it will not be needed until reassembly.
Now, the flex cables need to be disconnected.
There is no particular order they need to be disconnected in, as long as they all are disconnected.
Upon reassembly, it helps to swab all the contacts at the end of the cables with a degreaser such as Isopropyl alcohol.
Most of the cables can be disconnected by flipping up a tightening bar.
To do so, insert a plastic opening tool under the edge and pry up
Now that the cable is lose, use tweezers or just simply your fingers to pull out the cable.
The board now is ready to come out. It has a connector on the top right, so it cannot be pulled out quickly. Instead, slide a plastic opening tool under the top right of the board, and pry up.
Once the connector is disconnected, carefully remove the board and set it aside.
Reassembly: Make sure the black tube goes into the slot on the board, it's easy to miss.
Note on 17 C picture the board is removed and flipped upsidedown to show where the optical black tube inserts on re-assembly
The card reader can now be removed
Start by pushing the card reader in from the outside slot.
Once it's lose, lift the card reader out vertically
Insert the new part into the slot, and follow all the steps backwards. See notes for reassembly
In the photo for step 19, the pin board is attached to the card-reader slot. How are these connected? On e-Bay, I only see the pin board available for purchase (not the entire slot).
Looking forward to getting this done! Canon online estimated $175 for this repair plus a cleaning.
jessematthew@gmail.com
24 other people completed this guide.
19 Comments
Excellent guide! Some additional tips:
1. be extra sure that you've seated the ribbon connectors securely and correctly. I didn't and got an "Err 20". I disassembled, cleaned ribbons with alcohol, reassembled and it was fine.
2. It would be great if there was some pictures for removing the actual connector for the CF card from the housing. It was a little tricky but practicing using the old broken one will help you to seat the new one correctly.
Great guide. I was successful with my fix. A few more tips:
1. Eyepiece removal -- squeeze sides and SLIDE it upward toward the top of the camera.
2. Use a magnetic or slightly magnetized screw driver. On one of the tiny internal screws it came off my screw driver and dropped into the internals of the camera. I thought I was doomed, but after removing the main board and by carefully lifting and tilting the camera, I was able to find and retrieve it with tweezers.
3. When removing ribbon cables, the tightening bar flips up and the ribbon cable slides out (don't lift upward, slide it back toward the direction the cable comes from).
4. In step 13, I think he means "top left" corner and on my camera both cables had a tightening bar.
5. When reinserting the ribbon cables, I found it very helpful to use the tiny whole in the cable and pair of pointed tweezers to gently "squeeze" the ribbon cable into the connector. This also helped it go in straight.
After I reinstalled everything, I put in the battery, the empty battery signal blinking even on full charge.
nothing else showing.
Anyone know which part went wrong?
I have this same problem, where I'm stuck is with the main flex cable, which looks like it's not connected to anything.. help?
I think you should check the connection behind the main board (the power connector which slots in the power circuit under the top LCD)
Anri -
there is a video for doing this for a canon 5d mark I on youtube
Thank you thank you.... I made few mistakes.... one of the cable got detached and I have to tear my camera apart to be able to fix the cable that was going underneath the bottom....
Everything is working well now ! Thank you very much
Next time I will do it differently. I will draw on a piece of paper what I see and put a needle hole on each screw on the paper to place the screw inside it.
The screws come on different size so it is important to know where goes each. I had more screw to unscrew that what it was initially planned.
In step 1, how is the "rubber" part of the camera attached to the body? Double side tape or does it "snap" into the body? I'm curious as to how the rubber reattaches to the body of the camera w/o falling apart or feeling loose once you reassemble it.
Thanks
forgive my ignorance, but i have the same problem on my 6d, the process would be the same right?
Whilst I haven’t had to do this it is an excellent guide.. wish he’d done one one on the control knob and switch
Used this manual, thanks! I only replaced the pin part of the card reader, so with minimal expenses, 1hr of precision wrenching.
Hey Nick, would this work for a Canon Rebel XT camera?
Also, what is the name of the specific part?
Crazy helpful.
1. Beneath the connectors and board seen in Step 10 is a loose-looking connector that threw me, but apparently it’s supposed to be loose.
2. The board connector mentioned in Step 17 needs to be pressed intentionally. I failed to do this and couldn’t power up. Re-did everything and discovered my error.
Thanks much!
Thank you so much for posting this! I was able to get the part swapped out and fixed in under 1.5 hours. This saved me so much money!
So glad I found this guide! Had one of these cameras come into my shop for this PRECISE repair. I was amazed to find this guide and the instructions were clear, concise, and easy to follow! Kudos to the auther!
This is very educative. I will like to know to replace the lens holder as mine broken. I also need information from where to buy a replacement
