Campbell Hausfeld FP204800 Check Valve Replacement
  1. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: step 1, image 1 of 3 Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: step 1, image 2 of 3 Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: step 1, image 3 of 3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud: step 2, image 1 of 2 Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud: step 2, image 2 of 2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 Check Valve Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: step 3, image 1 of 1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 Check Valve Replacement, Remove the On/Off Switch Wiring: step 4, image 1 of 1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 Check Valve Replacement, Unscrew Exhaust Tube: step 5, image 1 of 1
    • Unscrew the exhaust tube from the check valve using a Smart Wrench.
  6. Campbell Hausfeld FP204800 Check Valve Replacement, Unscrew Check Valve: step 6, image 1 of 1
    • Unscrew the check valve by twisting it counter-clockwise using a Smart Wrench.
Caleb Davies
528 Reputation
4 Guides authored
Cal Poly, Team 14-29, Maness Fall 2014 Member of Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Members
7 Guides authored
2 Comments
I never thought that it will be that much easy. I was looking for this kind of guide and thanks to ifixit and author of this guide I have successfully did the check valve replacement. Thanks for sharing this.
http://zahroofvalves.com
Rodney A. Olsen - Reply
1. How do you know if it’s the pressure switch that’s bad?
2. What do ya do when they say the parts are discontinued??
Jennifer Epps - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,305
