Introduction
Use this guide to remove or replace the Campagnolo® Power Torque™ Crank system on your bike.
Tools
Parts
No parts required.
Remove the spring clip from the drive-side bearing adaptor.
  • Remove the spring clip from the drive-side bearing adaptor.
  • The crank cannot be removed with this clip in place.
  • Remove crank bolt using a 14mm hex wrench.
  • Remove any washers inside the arm.
Slide the plastic molded pad onto the crank. Insert the extension plug in the spindle.
  • Slide the plastic molded pad onto the crank.
  • Insert the extension plug in the spindle.
  • Engage the puller from the CBP-3 bearing puller set.
  • Fit the caliper arms over the molded pad.
  • Align the puller then use the knobs to remove play from the puller fingers.
    • The end of the puller fingers should engage the recess behind the mold.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Place a square of cardboard between the arm and crank to minimize scratching. Insert the extension plug in the arm.
  • Place a square of cardboard between the arm and crank to minimize scratching.
  • Insert the extension plug in the arm.
  • Align the puller then tighten the puller fingers to remove play.
  • Turn the puller handle clockwise to tighten it and pull the arm from the spindle.
  • Remove any seal or wave washer found in the left side.
  • Remove the puller from the crank.
  • Pull crank toward the drive side to remove it from the bike.
Park Tool
1,201 Reputation
4 Guides authored
Park Tool Member of Park Tool
Community
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 15
Past 30 Days: 18
All Time: 76
