Introduction
Use this guide to replace the motherboard of the Cambridge SoundWorks OontZ Angle Plus.
Pull back the six screw covers on the bottom of the device.
Starting from the screw covers, peel the casing away from the bottom plate.
Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
Remove the brace that holds the battery in place.
Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
