Introduction
In this guide we will replace the power cord and the transformer The transformer is the large, heavy device that converts the relatively high 220V input voltage into a lower voltage for the amplifier.
Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
It may require some wiggling, but it should slip out of the hole and then off of the cord.
Carefully de-solder ends of power cord from circuit board.
Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
Finally, pull the power cord through the rear panel to completely remove it.
