Introduction
Follow this guide to remove the riser main slider in order to repair or replace it.
Lift the slider and riser main pipe.
Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
Carefully lower the riser main and slider to allow it to rest on the rod clamp.
Remove the riser main slider, and inspect it for wear and tear.
Set the slider in a sanitary place to prevent contamination.
