Bush Pump Cylinder (Ndembele) Replacement
  1. Bush Pump Cylinder (Ndembele) Replacement, Head and Handle (Ndembele): step 1, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement, Head and Handle (Ndembele): step 1, image 2 of 2
    • Linga ukusebenza kwepompo ngokupompa amahlandla ama-40.
    • Ipompo ekungiyo fanele ibuyise nanyana malitha ali-10.
  2. Bush Pump Cylinder (Ndembele) Replacement: step 2, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 2, image 2 of 2
    • Susa amaphini amabili ahlanganisa isibambo esitjhelelini.
  3. Bush Pump Cylinder (Ndembele) Replacement: step 3, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 3, image 2 of 2
    • Dosa iimbambo ezimbili zomgqala kude nesitjheleli.
  4. Bush Pump Cylinder (Ndembele) Replacement: step 4, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 4, image 2 of 2
    • Phakamisa amaphini amabili abambene nesakhelelo sepompo nesibambo siyephezulu, kusukela esakhelweleni sepompo.
  5. Bush Pump Cylinder (Ndembele) Replacement: step 5, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 5, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 5, image 3 of 3
    • Ngokuya ngegadangweli, yenza mbala bona ulekelela isibambo nehloko ngananyana ngezandla ezintathu.
    • Tjhelelisa ibheringhi yentonga ngaphandle kwehloko.
    • Hlola ibheringhi yentonga nehloko ukobana ayikasinyeki nanyana ayikarathuki.
  6. Bush Pump Cylinder (Ndembele) Replacement: step 6, image 1 of 1
    • Susa ihloko nesibambo, uzibeke endaweni ehlwengekileko ukuvimbela ukusilaphazeka.
  7. Bush Pump Cylinder (Ndembele) Replacement, Riser Main Slider (Ndembele): step 7, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement, Riser Main Slider (Ndembele): step 7, image 2 of 2
    • Ngokuqina phakamisa isikhuphukeli sephayiphu edlulisa amanzi, ngezandla zombili.
    • Thlogomela ukobana ungawisi isikhuphukeli sephayiphu edlulisa amanzi ngombana lokho kungona ipompo nesilinda.
  8. Bush Pump Cylinder (Ndembele) Replacement: step 8, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 8, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 8, image 3 of 3
    • Sebenzisa isipanere sephayiphu ukulenza ligedle ubungaphezulu bephayiphu esikhuphukeleni.
  9. Bush Pump Cylinder (Ndembele) Replacement: step 9, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 9, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 9, image 3 of 3
    • Phakamisa isitjheleli nesikhuphukeli nephayiphu edlulisa amanzi.
    • Beka ipompo nentonga bese uyayiqinisa kuzungeza intonga, uyibophe uyiqinise hlangana nepompo nentonga.
    • Ngokutjheja yehlisa isikhuphukeli nephayiphu edlulisa amanzi nesitjheleli ukuvumela bona izithekghe phezu kwentonga kuqina.
  10. Bush Pump Cylinder (Ndembele) Replacement: step 10, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 10, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 10, image 3 of 3
    • Gedlisa bese ususa zombili ipompo nentonga bese uminyezele endaweni encani ngokungasikinyeki imbumbulu phezu kwesitjheleli.
  11. Bush Pump Cylinder (Ndembele) Replacement: step 11, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 11, image 2 of 2
    • Susa ingaphezulu lesikhuphukeli sephayiphu edlulisa amanzi, bese uyihlola bona ayikasinyeki nanyana ayikarathuki.
    • Beka isitjheleli endaweni enelanga ukwenzela bona ingasilaphazeki.
  12. Bush Pump Cylinder (Ndembele) Replacement, Above Grade Riser Pipe (Ndembele): step 12, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement, Above Grade Riser Pipe (Ndembele): step 12, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement, Above Grade Riser Pipe (Ndembele): step 12, image 3 of 3
    • Susa ngaphezu kwebanga wesikhuphukeli sephapiphu.
    • Ngokuqinileko krufela isibambo saka-T phezu kwepompo yentonga.
    • Nawujamisela iphayiphu elidlulisa amanzi nesikhuphukeli ngaphezu kwephasi, lisa isibambo se-T sibambelele kufikela ulungele ukufaka esinye isitoki esijamiselako.
  13. Bush Pump Cylinder (Ndembele) Replacement, Spout (Ndembele): step 13, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement, Spout (Ndembele): step 13, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement, Spout (Ndembele): step 13, image 3 of 3
    • Sebenzisa isikrufu sephayiphu ukugedlisa nokususa itjhubhu yepompo
    • Hlola itjhubhu bona ayithikamezeki nanyana isilaphazeke.
    • Beka itjhubhu endaweni ehlwengekileko ukuvimbela ukusilaphazeka.
  14. Bush Pump Cylinder (Ndembele) Replacement, Riser Main (Ndembele): step 14, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement, Riser Main (Ndembele): step 14, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement, Riser Main (Ndembele): step 14, image 3 of 3
    • Beka isikrufu sinye phezu kwepompo yesikhuphukeli sesitja samabowhudu.
    • Beka esinye isikrufu kuzungeza ngaphasi kwebhowudu.
    • Dosa iinkrufu uzihlukanise bona zigedlise amabhowudu.
    • Buyelela isenzekwesi emabhowudwini amathathu aseleko.
  15. Bush Pump Cylinder (Ndembele) Replacement: step 15, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 15, image 2 of 2
    • Susa iimbumbulu ezine namabhowudu avikele isikhuphukeli sepompo sesitja uzibeke esiphathweni esibona ilanga esinjenge bakhede.
  16. Bush Pump Cylinder (Ndembele) Replacement: step 16, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 16, image 2 of 2
    • Zungezisa isitja sepompo amadigri ama-45. Lokho kuzokwenzelela ukubamba okuncono nawuphakamisa isitja.
  17. Bush Pump Cylinder (Ndembele) Replacement: step 17, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 17, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 17, image 3 of 3
    • Ngokuvikela phakamisa isibambo se-T amanungu ambalwa.
    • Lokhana abantu ababili basekela isibambo se-T, susa ipompo yentonga.
    • Yehlisa isibambo se-T ngokusihlenga ipompo yentonga ikwazi ukuzijamele.
  18. Bush Pump Cylinder (Ndembele) Replacement: step 18, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 18, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 18, image 3 of 3
    • Umhlobo lo wepompo usebenzisa ipoto yennyawo ezintathu nesivimbo noku tjhewa ukuphakamisa isikhuphukeli sephayiphu edlulisa amanzi. Isikrufu se-C singasebenziswa ukuphakamisa isikhuphukeli sephayiphu edlulisa amanzi.
    • Ngokuvikela bamba bese uqinise isikhuphula phayiphu esikhuphukeleni sephayiphu edlulisa amanzi ngaphasi kwetjhuba letjhubhu.
  19. Bush Pump Cylinder (Ndembele) Replacement: step 19, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 19, image 2 of 2
    • Ngokutjheja ungaphunyukelwa yintambo, sebenzisa isivimbo netjhewa ukuphakamisa isikhuphukeli sephayiphu edlulisa amanzi kufikela isikhuphula phayiphu sifikelele isivimbo netjhewa.
  20. Bush Pump Cylinder (Ndembele) Replacement: step 20, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 20, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 20, image 3 of 3
    • Na isikhuphukeli sephayiphu edlulisa amanzi sifikelele isivimbo netjhewa, vikela ingaphasi bese uqinise hlangana nesikhuphukeli sephayiphu edlulisa amanzi.
  21. Bush Pump Cylinder (Ndembele) Replacement: step 21, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 21, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 21, image 3 of 3
    • Vikela umphasi ngokuqinisa esakhelelweni esiphasi usebenzise ibhowudu.
    • Ibhowudu yinye yanele ukubamba umphasi ukuqinisa umphakathi, ungangeza ngenye ibhowudu nawufuna ukuyiqinisa.
  22. Bush Pump Cylinder (Ndembele) Replacement: step 22, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 22, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 22, image 3 of 3
    • Nawusasekela umphezulu we phayiphu, ngokutjheja khambisa isikhuphula kuqinisa kude nephayiphu.
    • Yehlisa isikhuphula kuqinasa bese ugedlisa ukuya ehlabathini ukuvimbela iintambo bona zirarane esivimbweni netjheweni.
  23. Bush Pump Cylinder (Ndembele) Replacement: step 23, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 23, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 23, image 3 of 3
    • Bambanisa isikhuphula kuqinisa esikhuphukeleni sephayiphu edlulisa amanzi eduze naphasi ngokukghonekako.
  24. Bush Pump Cylinder (Ndembele) Replacement: step 24, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 24, image 2 of 2
    • Na isikhuphula kuqinisa siqinileko, yenza ukugedla entambeni.
    • Nawugedlisa iintambo usekela isikhuphukeli, gedlisa umphasi kuqinisa.
  25. Bush Pump Cylinder (Ndembele) Replacement: step 25, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 25, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 25, image 3 of 3
    • Sebenzisa intambo ukudosa isikhuphukeli sephayiphu edlulisa amanzi phezulu kabuthaka.
    • Ynza mbala bona intambo ihlangana nepoto yennyawo ezintathu ukuvikela ipoto yennyawo ezintathu ingaweli phasi.
    • Qala umphezulu wepoto yennyawo ezintathu bona ulinganele nesikhuphukeli sephayiphu edlulisa amanzi bona ibe seskhaleni esisekelako.
  26. Bush Pump Cylinder (Ndembele) Replacement: step 26, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 26, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 26, image 3 of 3
    • Susa ukuqinisa esikhuphukeleni sephayiphu edlulisa amanzi bese ubuyelela amagadango ama-23 ukuya kwama-25 kufikela isihlanganisi sembuke.
  27. Bush Pump Cylinder (Ndembele) Replacement: step 27, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 27, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 27, image 3 of 3
    • Na isihlanganisi sokuthoma siveziwe, qinisa umphasi ngaphasi kwesihlanganisi.
  28. Bush Pump Cylinder (Ndembele) Replacement: step 28, image 1 of 1
    • Susa isikhuphula kuqinisa ukusuka esikhuphukeleni sephayiphu esidlulisa amanzi bese uvikela epotweni yennyawo ezintathu ukuyisusa endleleni.
  29. Bush Pump Cylinder (Ndembele) Replacement: step 29, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 29, image 2 of 2
    • Phatha isikrufu sephayiphu amanungu ambalwa ngaphezu kwesihlanganisi egadangweneli.
    • Usebenzisa isikrufu sephayiphu, uyasikrufulula esigabeni sokuthoma sesikhuphukeli phayiphu edlulisa amanzi ehlanganweni.
  30. Bush Pump Cylinder (Ndembele) Replacement: step 30, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 30, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 30, image 3 of 3
    • Vikela ipetjhe yegadi phezu kwesihlanganisi ukuvikela amanzi bona arhatjheke na innhlanganisi zehlukanisiweko.
    • Usebenzisa isikrufu sepompo, gedlisa isikhuphukeli sephayiphu edlulisa amanzi fikela amanzi athome ukuthulukela ngaphakathi kwepetjhe yegadi.
    • Unga gedlisi kuya phambili kufikela amanzi ajame ukuphuma.
  31. Bush Pump Cylinder (Ndembele) Replacement: step 31, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 31, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 31, image 3 of 3
    • Susa ipetjhe yegadi bese uqedelela ukugedlisa isikhuphukeli sephayiphu edlulisa amanzi.
    • Susa isigaba sokuthoma sesikhuphukeli sephayiphu edlulisa amanzi ngokuyiphakamisa ijame ilinganisele, bese usekela umphezulu wesigaba bese ubeka ipompo uyisekele esikhaleni phezulu kwepoto yennyawo ezintathu.
  32. Bush Pump Cylinder (Ndembele) Replacement: step 32, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 32, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 32, image 3 of 3
    • Bambanisa bese uqinisa intonga amanungu ambalwa ngaphasi kwentonga yepompo yokuthoma ebambeneko.
  33. Bush Pump Cylinder (Ndembele) Replacement: step 33, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 33, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 33, image 3 of 3
    • Usebenzisa inkrufu ze-C, krufulula intonga yepompo engcenyeni eseleko.
    • Na isihlanganisi sahlukeneko, ngokutjheja yehlisa isikhuphukeli sephayiphu edlulisa amanzi ehlabathini.
  34. Bush Pump Cylinder (Ndembele) Replacement: step 34, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 34, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 34, image 3 of 3
    • Ngokutjheja yehlisa isikhuphukeli sephayiphu, ukuyaphezulu, bese ubeka endaweni enelanga, kuhle uyisame ngaphezu kwehlabathi, ukuvikela ukusilaphazeka.
  35. Bush Pump Cylinder (Ndembele) Replacement: step 35, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 35, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 35, image 3 of 3
    • Susa isibambo se-T kusuka epompeni yentonga ehlukanisiweko.
    • Bambanisa isibambo se-T epompeni yentonga eseleko.
    • Susa intonga eqinileko bese ubuyelela amagadango ama-29 ukuya kwama-35 fikela isikhuphukeli sephayiphu edlulisa amanzi sisuke soke, nanyana isigaba esaphukileko sifikelelwe.
  36. Bush Pump Cylinder (Ndembele) Replacement, Cylinder (Ndembele): step 36, image 1 of 1
    • Tjheja bona ubeka isilinda kude nehlabathi ukobana ingasinyeki nanyana isilaphazeke.
  37. Bush Pump Cylinder (Ndembele) Replacement: step 37, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 37, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 37, image 3 of 3
    • Usebenzisa amabhowudu wamaphayiphu amabili, skrufulula isilinda esikhuphukeni sephayiphu edlulisa amanzi.
  38. Bush Pump Cylinder (Ndembele) Replacement: step 38, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 38, image 2 of 2
    • Buthaka dosa isilinda esuka epompeni yentonga bese ulisa ivelifu ekhambako nevelifu yenyawo.
Ukubuyisela into oyenzele ihloso ethileko, landela ifundiso ngendlela ethoma samva.
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 206
