Bullnose Tile Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
123
All Time:
517
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 4 hours
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through how to reattach bullnose tiles that have fallen off, letting you complete this home repair for little to no monetary spending instead of paying someone else potentially hundreds to do this for you. This guide requires the prerequisite knowledge of how to use attach a silicon sealant tube (a grout tube) to a caulk gun and how to operate a caulk gun as a caulk gun will be used in steps 20 and 21. To learn more about operating a caulk gun, visit this page.
    1. Bullnose Tile Replacement, Bullnose Tile: step 1, image 1 of 1
      • Collect all bullnose tile pieces that have fallen off into one place.
      Ask FixBot
    2. Bullnose Tile Replacement: step 2, image 1 of 1
      • Locate the place where the bullnose tiles previously were (where the tiles broke off from).
      Ask FixBot
    3. Bullnose Tile Replacement: step 3, image 1 of 2 Bullnose Tile Replacement: step 3, image 2 of 2
      • Align any tiles that may have broken.
      Ask FixBot
    4. Bullnose Tile Replacement: step 4, image 1 of 1
      • To check you have all the tiles in the correct alignment, place the bullnose tiles along the edge that they broke off of to make sure they fit.
      • Remember, the standard size tiles (typically the longer ones) should be placed towards the center with the remaining tiles (typically the shorter ones) on the edge.
      Ask FixBot
    5. Bullnose Tile Replacement: step 5, image 1 of 1
      • To double check the order, find the perfect fit between the tile and the remaining grout (where the tile lies flush with the grout).
      Ask FixBot
    6. Bullnose Tile Replacement: step 6, image 1 of 1
      • Now that you are sure, flip the tiles over so their underside is accessible.
      Ask FixBot
    7. Bullnose Tile Replacement: step 7, image 1 of 1
      • Sand off any extra bits attached to the tile that will impact reattachment (for example, general debris or unsavable tile slivers).
      • Keep in mind that some texture is good for the later reattachment, so sand sparingly.
      Ask FixBot
    8. Bullnose Tile Replacement: step 8, image 1 of 1
      • Clean off your space to avoid accidentally gluing grime back onto your tiles.
      Ask FixBot
    9. Bullnose Tile Replacement: step 9, image 1 of 1
      • Prepare about three strips of painter's tape per complete tile or one per broken tile piece.
      • These tape strips will be used to hold the tiles in place while the glue dries, so make each one long enough to secure tightly over both sides of the tile.
      Ask FixBot
    10. Bullnose Tile Replacement: step 10, image 1 of 1
      • Apply Gorilla Glue generously to the interior sides of the tile, as well as the corner edge that will be pressed into the tile.
      • Ensure the room in which this project is taking place is well ventilated.
      Ask FixBot
    11. Bullnose Tile Replacement: step 11, image 1 of 1
      • Apply glue generously to the surface you are attempting to reattach the tile to.
      • Make sure to glue one tile area at a time to avoid premature glue drying.
      Ask FixBot
    12. Bullnose Tile Replacement: step 12, image 1 of 1
      • Press and hold your glued tile into your glued surface.
      Ask FixBot
    13. Bullnose Tile Replacement: step 13, image 1 of 1
      • Use your painters tape to hold the glued tile and surface together while the glue dries.
      Ask FixBot
    14. Bullnose Tile Replacement: step 14, image 1 of 1
      • Continue these last five steps for all the bullnose tiles you are reattaching.
      • The glue will take 1-2 hours to dry.
      Ask FixBot
    15. Bullnose Tile Replacement: step 15, image 1 of 1
      • Use a paper towel to clean off as much dripping glue as you can.
      • Do not worry if you miss some; later there will be a more thorough glue cleanup step once the glue is dried.
      Ask FixBot
    16. Bullnose Tile Replacement: step 16, image 1 of 1
      • While drying, the glue may foam and eventually become firm when dried. This is normal. This is how industrial grade glue gets to as much surface as possible for the best attachment.
      Ask FixBot
    17. Bullnose Tile Replacement: step 17, image 1 of 1
      • Once the glue is dry, remove the painters tape.
      • The tape directly touching the glue will be harder to remove, so do not focus on removing those pieces right now. They will be removed later alongside dried excess glue.
      Ask FixBot
    18. Bullnose Tile Replacement: step 18, image 1 of 2 Bullnose Tile Replacement: step 18, image 2 of 2
      • Use your razor cutter to chip off the excess dried glue.
      • Remember to get the glue that has dripped past your working area as well.
      • Make sure you are never in the cutting path of the blade.
      Ask FixBot
    19. Bullnose Tile Replacement: step 19, image 1 of 1
      • Use your standard scraper to remove as much dried glue that found its way between your tiles. This space should be made as clear as possible for grout.
      Ask FixBot
    20. Bullnose Tile Replacement: step 20, image 1 of 1
      • Squeeze your grout into the gap.
      • You are done when the grout pushes out all three exposed sides. This is how you know that the gap is filled completely.
      Ask FixBot
    21. Bullnose Tile Replacement: step 21, image 1 of 1
      • Apply grout alongside the exposed edges of the tiles as well. Use the grout that remains from the original design to mark where yours should go.
      Ask FixBot
    22. Bullnose Tile Replacement: step 22, image 1 of 1
      • Wipe off the excess grout with a damp paper towel.
      Ask FixBot
    23. Bullnose Tile Replacement: step 23, image 1 of 1
      • Wait for the grout to dry and SUCCESS! Enjoy your reattached bullnose tiles!
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 123
All Time: 517
