Shop the Holiday Gift Guide
Brown multipractic timing belt replacement
Views: 5.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
47
Past 30 Days:
174
All Time:
5,217
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
If the engine is running on your Braun food processor, but the drive shaft is not rotating anymore or just stuttering, the timing belt connecting the motor to the shaft may be damaged. He is easy to exchange.
    1. Brown multipractic timing belt replacement, toothed belt: step 1, image 1 of 1
      • Remove the stirring container.
      • Turn the machine upside down
      Ask FixBot
    2. Brown multipractic timing belt replacement: step 2, image 1 of 2 Brown multipractic timing belt replacement: step 2, image 2 of 2
      • Sometimes the screws are hidden under the rubber feet. Then you have to pull them out.
      Ask FixBot
    3. Brown multipractic timing belt replacement: step 3, image 1 of 2 Brown multipractic timing belt replacement: step 3, image 2 of 2
      • Unscrew the screws on the bottom plate.
      • Take off the bottom plate.
      Ask FixBot
    4. Brown multipractic timing belt replacement: step 4, image 1 of 2 Brown multipractic timing belt replacement: step 4, image 2 of 2
      • Clearly visible: the timing belt is touched!
      • The timing belt size is printed. In this model multipractic it is one of the type 190 XL 037.
      • With the right name it is easy to buy.
      Ask FixBot
    5. Brown multipractic timing belt replacement: step 5, image 1 of 1
      • The new belt is laid on. First on the small drive wheel, then on the large drive wheel, sit there on one side and spin once.
      Ask FixBot
Repeat the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
346,513 Reputation
317 Guides authored
1 Guide Comment
Any guide for replacing belt for Braun Fx 3030 processor
Sajith kakkattil - Reply Share
Past 24 Hours: 6
Past 7 Days: 47
Past 30 Days: 174
All Time: 5,217
