Brother PT-D200 Circuit Board Cables Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Brother PT-D200 Circuit Board Cables Replacement, Circuit Board Cables: step 1, image 1 of 1
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  2. Brother PT-D200 Circuit Board Cables Replacement: step 2, image 1 of 1
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
Jeston Mitchell
308 Reputation
3 Guides authored
Cal Poly, Team 13-16, Regan Winter 2014 Member of Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 36
