Brown multipractic timing belt replacement
  1. Brown multipractic timing belt replacement, toothed belt: step 1, image 1 of 1
    • Remove the stirring container.
    • Turn the machine upside down
  2. Brown multipractic timing belt replacement: step 2, image 1 of 2 Brown multipractic timing belt replacement: step 2, image 2 of 2
    • Sometimes the screws are hidden under the rubber feet. Then you have to pull them out.
  3. Brown multipractic timing belt replacement: step 3, image 1 of 2 Brown multipractic timing belt replacement: step 3, image 2 of 2
    • Unscrew the screws on the bottom plate.
    • Take off the bottom plate.
  4. Brown multipractic timing belt replacement: step 4, image 1 of 2 Brown multipractic timing belt replacement: step 4, image 2 of 2
    • Clearly visible: the timing belt is touched!
    • The timing belt size is printed. In this model multipractic it is one of the type 190 XL 037.
    • With the right name it is easy to buy.
  5. Brown multipractic timing belt replacement: step 5, image 1 of 1
    • The new belt is laid on. First on the small drive wheel, then on the large drive wheel, sit there on one side and spin once.
Repeat the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
202,421 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,103 Guides authored
One Comment
Any guide for replacing belt for Braun Fx 3030 processor
Sajith kakkattil - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 50
All Time: 3,215
