Introduction
This guide gets you into this classic coffee grinder.(You will get some extra jealous looks from your hipster friends because it's soooo vintage ;-D)
First, remove the coffee powder container
Now it's time to rotate the bean container anti-clockwise to remove it from the machine
Hallo, habe gerad ein Exemplar bei Kleinanzeigen ergattert, allerdings kann ich den oberen Teil gar nicht drehen. Weder um den mahlgrad einzustellen, noch um das Ding abzunehmen. Gibt es einen Trick oder liegt es vielleicht am Schmutz? Freue mich über Anregungen
16 other people completed this guide.
9 Comments
Hi Daniel,
Thanks for the tutorial.
Would you have, by any chance, the usermanual of the grinder?
I’m wondering to what grinding size the numbering is corresponding to.
Many thanks! :)
Best regards,
Greg
I have this same issue! Did you ever find out? Im guessing that the grind size of the KMM1 is the same as the KMM20? So left (where it says mocca)for finest grind, right for the largest grind?
Look at the explosion view
Umm.. My bottom burr doesn’t seem to have screws and look like rivits. maybe previous owner stripped the screws :(
Mine has something like rivets as well. I used toothpicks and cotton swabs to clean as much as I could,, then had some luck running dried couscous through the grinder. Softer than rice and seemed to pick up the last bits of residue.
Gilt diese Anleitung zur Reinigung auch für die Braun Kaffeemühle 4045?
Könnte sein. Das Gerät heißt KMM 20 Typ 4045, vermutlich eine Weiterentwicklung der KMM 1.
VauWeh -
My grinder is stuck on course how to I “clean it” recalibrate it?
Thanks
