Introduction
Use this guide to learn how to replace your battery for the Bowers and Wilkins T7 Bluetooth Speaker.
Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
There are 8 screws in total.
Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
As the cover starts to come off, you can lift up using your hand.
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
Using a cutting tool such as a Jimmy steel blade or wire cutter, cut the cable tie surrounding the battery.
Using the ifixit Opening Tool, pry out the battery power supply connector.
Pull and remove the battery power supply connector.
