Bosch PMF 180 E power cord / plug replacement
  1. Bosch PMF 180 E power cord / plug replacement, Power cord / plug: step 1, image 1 of 2 Bosch PMF 180 E power cord / plug replacement, Power cord / plug: step 1, image 2 of 2
    • Absolutely disconnect the device as the first of the power (;-). Safety first!
    • If necessary, just a little bit of external cleaning so that when opening no additional dirt into the housing interior. for example with the fine brush but it is also an old toothbrush or a bristle brush, etc.
    • Very useful: An exploded view with spare part designation at the end of the description.
  2. Bosch PMF 180 E power cord / plug replacement: step 2, image 1 of 1
    • Loosen 9 screws (combination screw T20 / slot # 5)
    • Tool: T20 / TR20 which u.a. included here. Or with a flat-head screwdriver # 5. I recommend a T20 / TR20 because it handles better without damaging the screws.
  3. Bosch PMF 180 E power cord / plug replacement: step 3, image 1 of 2 Bosch PMF 180 E power cord / plug replacement: step 3, image 2 of 2
    • With a flat object, the housing can now be easily opened along the seam. For example, with Jimmy, which is shown here. It also works with a flat knife or a thin Japan spatula.
    • If the unit is heavily used / dirty, simply pry slightly at several points along the seam until the case opens without force.
  4. Bosch PMF 180 E power cord / plug replacement: step 4, image 1 of 3 Bosch PMF 180 E power cord / plug replacement: step 4, image 2 of 3 Bosch PMF 180 E power cord / plug replacement: step 4, image 3 of 3
    • The housing is now open and further steps can be taken.
    • If necessary can now be cleaned. (in this picture you can see that it is obviously necessary)
    • Do not remove the grease! The drive needs that. Of course, it can also be replaced by a new one.
  5. Bosch PMF 180 E power cord / plug replacement: step 5, image 1 of 2 Bosch PMF 180 E power cord / plug replacement: step 5, image 2 of 2
    • Now first loosen the two slotted screws # 3 so that the wires can be pulled out of the clamp.
  6. Bosch PMF 180 E power cord / plug replacement: step 6, image 1 of 2 Bosch PMF 180 E power cord / plug replacement: step 6, image 2 of 2
    • Pull the wires out of the holder with a gripping tool. For example, with a pair of tweezers or a small, flat pair of pliers.
  7. Bosch PMF 180 E power cord / plug replacement: step 7, image 1 of 3 Bosch PMF 180 E power cord / plug replacement: step 7, image 2 of 3 Bosch PMF 180 E power cord / plug replacement: step 7, image 3 of 3
    • Now loosen the two screws (T20 / slot # 5) of the cable lock and remove the clamp.
    • The cable can now be pulled out of the grommet and replaced
Repeat the steps in order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Sandro Torchella
290 Reputation
1 Guide authored
iFixit EU Team Member of iFixit EU Team
Staff
46 Members
1,094 Guides authored
One Comment
To right of green holder there is a looped black and white wire that goes underneath. Where does it attach to as mine is loose below coil, between coil and case. Tool just stopped working mid use. No burning smell and no other loose connections. There is a moulding.on case that it fits into but no attachment anywhere. Coil has a small dent where small bend in wire appears to have sat
MsMacGyver - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 22
All Time: 2,391
