This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance
    1. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Casing Cover Removal: step 1, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Casing Cover Removal: step 1, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Casing Cover Removal: step 1, image 3 of 3
      • Disconnect the power supply of your grinder before any disassembly operation.
      • The casing cover is secured by six 4 x 25 mm T20 Torx screws. Three screws under the left side and three screws under the right side.
      • Using a screwdriver with a T20 Torx driver bit, remove the six screws securing the casing cover.
      • Remove the casing cover by lifting it up.
      Ask FixBot
    2. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Switch plate removal: step 2, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Switch plate removal: step 2, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Switch plate removal: step 2, image 3 of 3
      • Remove the two 4 x 20 mm Torx screws located on the left side of the plate.
      • Also remove the two 4 x 20 mm Torx screws located on the right side of the plate.
      • Unclip the top part of the plate by pressing slightly inward with your thumb while pulling it towards you. Perform this operation for both sides.
      Ask FixBot
    3. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 3, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 3, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 3, image 3 of 3
      • Using a plastic opening tool, pry each of the two sides of the switch plate away from the earcup at the bottom screw.
      • Move the switch plate out of the way by about 12 inches (30 cm) by pulling it gently toward you. It is held by two electrical connections.
      • Disconnect the ground wire by pulling on it at the back of the power socket.
      • Disconnect the connector by pulling firmly while wiggling the male end from left to right. It is not held by any snap fits, but features four flat lugs.
      • The switch plate is removed.
      Ask FixBot
    1. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Disassembling the frame: step 4, image 1 of 2 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Disassembling the frame: step 4, image 2 of 2
      • Before removing the frame screws, lay your shredder on its side on the floor, with the frame wheels facing up.
      • By doing this, it will not fall from a height when the frame screws are removed. You can also slide a one to two-centimeter shim under its lower part.
      • Using a 10 mm wrench or socket, remove the 4 M6 x 45mm hex frame screws (two screws on each side)
      Ask FixBot
    2. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Disassembling the housing: step 5, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Disassembling the housing: step 5, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Disassembling the housing: step 5, image 3 of 3
      • Remove the four 4 x 25 mm T20 screws on the front of the housing.
      • Remove the three 4 x 25 mm T20 screws located between the motor and the grounds outlet.
      • These three screws are at a depth of 60 mm. The tool used (screwdriver or socket with extension) must not have a maximum diameter greater than 12 mm.
      • Remove the 5 x 16 mm T25 screw.
      • Remove the six 4 x 25 mm T20 screws located on the bottom and back of the housing.
      • Lift and remove the left half-housing.
      Ask FixBot
    3. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 6, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 6, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 6, image 3 of 3
      • Be careful not to damage the motor cooling fan. After turning the shredder over, place it down gently or on a block positioned on the rear part of the motor.
      • Turn the shredder over and set it down.
      • Remove the 5 x 16 mm T25 screw that secures the housing half to the shredder body.
      • Lift and remove the right housing half.
      Ask FixBot
    4. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Disassembling the bearing flange: step 7, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Disassembling the bearing flange: step 7, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Disassembling the bearing flange: step 7, image 3 of 3
      • Using a 5 mm hex (Allen) wrench, remove the four M6 x 25 mm socket head screws from the bearing flange.
      • Using a ball-end wrench makes it easier to completely unscrew the screws once they have been loosened.
      • Pull on the flange while moving it slightly (it comes off easily) and remove it.
      Ask FixBot
    5. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the hopper: step 8, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the hopper: step 8, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the hopper: step 8, image 3 of 3
      • Remove the plant material input hopper (if it did not come off with the bearing flange).
      Ask FixBot
    6. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the cutting ring: step 9, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the cutting ring: step 9, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the cutting ring: step 9, image 3 of 3
      • Remove the cutting ring (cup) by pulling it toward you.
      • For reassembly, note the notch on the ring, which must be placed into the slot on the bearing flange.
      Ask FixBot
    7. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Checking the bearing: step 10, image 1 of 2 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Checking the bearing: step 10, image 2 of 2
      • Let's take advantage of this disassembly to check the condition of the bearing.
      • The inner race of the bearing must rotate easily, without any stiff points, and must not have any mechanical play.
      • Clean the visible face of the bearing with a cloth, without using any product. The bearing is water resistant and is lubricated for life.
      • This 6203-2ZR (or ZZ or 2Z) type bearing is common and inexpensive (< 10 euros). Its specifications: 17 mm inner diameter, 40 mm outer diameter, 12 mm thickness, double metal seal. To replace it, an internal bearing puller will be necessary.
      Ask FixBot
    8. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the motor fastener screws: step 11, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the motor fastener screws: step 11, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the motor fastener screws: step 11, image 3 of 3
      • Place the motor/grinding chamber assembly vertically on blocks, with the motor cooling fan facing upward (so that it does not rest on the protruding blade shaft or damage the motor cooling fan).
      • Using a 5 mm hex (Allen) wrench, remove the three M6 x 25 mm socket head cap screws securing the motor.
      Ask FixBot
    9. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Removing the motor: step 12, image 1 of 1
      • Lift the motor and gently set it down on its cooling fan (be careful not to damage the cooling fan).
      Ask FixBot
    10. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the two planetary gears: step 13, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the two planetary gears: step 13, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Remove the two planetary gears: step 13, image 3 of 3
      • Remove the retaining ring from both planetary gears using two flathead screwdrivers. Insert the screwdrivers into the two notches of each retaining ring and turn them inward.
      • Lift the two gears and place them on a clean surface.
      • You can now check the condition of the bearings and the gear teeth, as well as the teeth of the motor pinion and the ring gear.
      • The planetary gears, the retaining rings, and the planetary transmission cage are available as spare parts under the respective Bosch parts list references 112, 134, and 808.
      • For reassembly, replace the old grease on the gears with a complex lithium grease suitable for high-load gears. Grease the inside of the bearings and fill the teeth with grease.
      Ask FixBot
    1. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Removing the helical blade: step 14, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Removing the helical blade: step 14, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance, Removing the helical blade: step 14, image 3 of 3
      • Preferably wear a pair of safety glasses and use a suitable tool in good condition. The snap ring, which is quite large, can "pop" off.
      • The snap ring holds the helical blade in place, so it will fall. Slide a shim under the blade if necessary to avoid damaging its shaft.
      • Using external snap ring pliers, spread the two ends of the snap ring and remove it from the shaft from above.
      • Remove the helical blade from its bearing from below.
      Ask FixBot
    2. Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 15, image 1 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 15, image 2 of 3 Bosch AXT 1600 HP Helical Blade Disassembly and Maintenance: step 15, image 3 of 3
      • The blade is associated with a part called a scraper, which is held in place by a large 42 mm circlip. Just like the blade, this part is no longer available as a replacement part.
      • The removed blade is damaged in two places. As the shredder in this guide is generally in good condition and still effective, the bent steel (on the left) will be ground down and the entire blade sharpened (at a wider angle than for a knife, at least 40 degrees).
      • For reassembly, ensure that no foreign bodies (iron filings, sand, dirt, dust, etc.) are present on the shafts, in the bearings, or in the gearbox with the gears. Remove the old grease from the bearings and gear teeth. Replace it with a generous application on all gear teeth.
      • The mechanical longevity of your shredder depends directly on the quality of the grease and the quality of the lubrication.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Ecuval
2,793 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 106
All Time: 2,080
