This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
In order to overhaul the alternator with approx. 300,000 km mileage, it must first be dismantled.
Problem: despite a new charge regulator, less than 14 V is being supplied.
Order number for bearing
Order number for sliding contact
Charge regulator with carbon brushes (one unit)
Cold cleaner or similar is useful for cleaning the generator, which is usually very dirty.
Remove the regulator: two screws (slotted in the original)
The carbon brushes should still protrude by at least 5 mm, otherwise replace the carbon brushes or the entire regulator. Here they are 12 mm.
On older alternators, the screws may be rusted solid. Spray generously with rust remover or penetrating oil and allow to soak in for a while if necessary.
Unscrew the nuts and washers (if present) on the two/four pull arms.
Unscrew the nuts and washers on the positive contact bolt (13 mm).
Unscrew the nuts, washers, and contact tongue from the control line (7 mm).
Unscrew the nuts, washers, and contact tab from the control line (7 mm).
Unscrew the belt pulley: hold it in place with an old belt and unscrew it with a wrench or ratchet. (22 mm)
Remove the nut and all washers as well as the fan blade, noting the order.
Remove the crescent key.
Mark the alternator housing for later reassembly.
If the four tie rods (screws) are of different lengths, note or mark where each one belongs
Unscrew the four screws (PH2).
Pull out the front housing part with the stator, using a plastic hammer to help if necessary.
Remove the four countersunk screws
Pull the rotor out of the bearing shield (housing).
Bearing shield and screws
Check: between the commutator segments 2.8 ohms +/- 10%, no contact with the housing?
Even if the resistance is correct, the contacts are so worn that the commutator ring must be replaced.
Remove the two bearings from the rotor shaft; a good bearing puller is helpful.
In the rear housing, remove the two screws that connect the diode plate to the housing
Pull the diode set and stator winding out of the housing
Do not lose the plastic bushing (or sliding ring).
Desolder the three stator cables.
Check the stator windings for short circuits to ground. Target: infinite resistance
Check continuity of the stator windings (the displayed 0.3 ohms) are inaccurate but continuity is present
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
95%
These translators are helping us fix the world! Want to contribute?
Start translating ›
