Introduction
Installing a Micro-SD card is a quick and easy way to expand your device's storage. Follow this guide to install your Micro-SD card correctly.
To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
Find the Micro-SD card slot which is under the right SIM card slot.
Line up the gold pins of the Micro-SD card with the pins of the card slot. If pins in the slot are hidden, then insert the Micro-SD card with the "MicroSD" print up and the pins facing the slot.
Slide the card into the slot until you either hear a clicking noise or until the card does not move anymore. Do not apply too much force; gently slide it in and stop immediately when it does not move anymore.
Your phone should boot up and ask you to format your Micro-SD Card.
Format the card and you're good to go.
My SD card was working just fine, then suddenly doesn't read. Attempted to remove and reinsert, but still doesn't read.
8 other people completed this guide.
