Fix Your Stuff
Right to Repair
Store
  1. Carefully remove the top plastic cover. It is hold in place by adhesive.
    • Carefully remove the top plastic cover. It is hold in place by adhesive.
  2. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Shop Now
    Shop Now
  3. Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off. Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
  4. Now the speaker just slides out.
    • Now the speaker just slides out.
2 other people completed this guide.
raven
536 Reputation
2 Guides authored
2 Comments
Trickiest part was removing the top piece. I used a razor blade to lift the edge, then a guitar pick to finish pulling it up. Thanks for the instructions.
Brian Wiebe - Reply
Be careful with the razor blade or it will slice the top of the flex which you can see folded over the top of the frame. This is not what you will really want to do as you will now be replacing the flex too.
eric Aspinall - Reply
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 88
All Time: 3,127
