Introduction
For removing and replacing the Blackberry 7520 battery, follow this guide.
Tools
No tools required.
Parts
No parts required.
Turn the phone upside down.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
  • To install the battery turn the phone on its back.
  • Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle)
  • Once the battery is lined up push the battery in and down until it is locked in.
  • Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone.
  • Push the panel inwards then down until it locks in.
  • Once the panel is in you have successfully changed your battery!
Finish Line
Nathan
31 Reputation
7 Guides authored
Cal Poly, Team 5-7, Forte Winter 2010 Member of Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,429
