BlackBerry Z10 Motherboard Assembly Replacement
  1. BlackBerry Z10 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 2 BlackBerry Z10 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 2 of 2
    • This is the easiest repair I've completed yet.
  2. BlackBerry Z10 Motherboard Assembly Replacement: step 2, image 1 of 3 BlackBerry Z10 Motherboard Assembly Replacement: step 2, image 2 of 3 BlackBerry Z10 Motherboard Assembly Replacement: step 2, image 3 of 3
    • The rear panel pops off easily. Grab the opening at the bottom and work your way around.
  3. BlackBerry Z10 Motherboard Assembly Replacement: step 3, image 1 of 2 BlackBerry Z10 Motherboard Assembly Replacement: step 3, image 2 of 2
    • There is NO adhesive on this device. NO ADHESIVE!!
  4. BlackBerry Z10 Motherboard Assembly Replacement: step 4, image 1 of 3 BlackBerry Z10 Motherboard Assembly Replacement: step 4, image 2 of 3 BlackBerry Z10 Motherboard Assembly Replacement: step 4, image 3 of 3
    • There's about 7 screws here. Remove the black circle sticker to uncover a hidden screw.
  5. BlackBerry Z10 Motherboard Assembly Replacement: step 5, image 1 of 3 BlackBerry Z10 Motherboard Assembly Replacement: step 5, image 2 of 3 BlackBerry Z10 Motherboard Assembly Replacement: step 5, image 3 of 3
    • Disconnect the logic board connector near the top and left side.
    • Underneath the connector on the left side, there's two other connectors. Disconnect those.
    • Remove the logic board and viola, you're done! Easiest repair in life!! To reassemble follow this guide in reverse. Happy repairing!
21 other people completed this guide.
Daniel Edwards
718 Reputation
1 Guide authored
2 Comments
For what is the second Screwdriver and what size is the right on?
Stefan Schenk - Reply
Will changing the motherboard assembly change my imei. I am wondering if I need to check the imei of the new motherboard to make sure it isn’t from a flag phone before install it.
phnark - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 17,186
