Black and Decker JE2200B Motor Compartment Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
109
All Time:
2,090
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The motor compartment is located on the bottom of the juicer. In this compartment there are many wires. Make sure the machine is off and unplugged before accessing the compartment. Use caution when working with the wires as electric shock can happen.
Tools
    1. Black and Decker JE2200B Motor Compartment Replacement, Motor Compartment: step 1, image 1 of 1
      Ask FixBot
    2. Black and Decker JE2200B Motor Compartment Replacement: step 2, image 1 of 2 Black and Decker JE2200B Motor Compartment Replacement: step 2, image 2 of 2
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Use the 2.5 mm Flathead adapter to remove the 13.5 mm screws from the bottom of the juicer. The screw head diameter is 5.2 mm.
      Ask FixBot
    3. Black and Decker JE2200B Motor Compartment Replacement: step 3, image 1 of 2 Black and Decker JE2200B Motor Compartment Replacement: step 3, image 2 of 2
      • Carefully remove the bottom off the rest of the machine.
      Ask FixBot
    4. Black and Decker JE2200B Motor Compartment Replacement: step 4, image 1 of 1
      • Lay the juicer horizontally and roll the top shaft cover until it comes off.
      Ask FixBot
    5. Black and Decker JE2200B Motor Compartment Replacement: step 5, image 1 of 1
      • Unscrew the 19.1 mm screws inside the juicer holding the motor compartment attached to the juicer. Use the 2.5 mm Flathead adapter as the screw driver. The diameter of the screw head is 7.1 mm.
      Ask FixBot
    6. Black and Decker JE2200B Motor Compartment Replacement: step 6, image 1 of 3 Black and Decker JE2200B Motor Compartment Replacement: step 6, image 2 of 3 Black and Decker JE2200B Motor Compartment Replacement: step 6, image 3 of 3
      • Remove the motor compartment from the juicer and it is ready to be replaced.
      Ask FixBot
4 other people completed this guide.
Bhavika Shah
331 Reputation
2 Guides authored
USF Tampa, Team 5-5, Blackwell Fall 2015 Member of USF Tampa, Team 5-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 109
All Time: 2,090
