Black and Decker BDH9600CHV Filter Button Replacement
  1. Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: step 1, image 1 of 3 Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: step 1, image 2 of 3 Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: step 1, image 3 of 3
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Filter Button Replacement: step 2, image 1 of 1
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Filter Button Replacement: step 3, image 1 of 2 Black and Decker BDH9600CHV Filter Button Replacement: step 3, image 2 of 2
    • Pull the housing apart.
    • Note when the housing is taken apart some parts may fall out be sure to keep track of any parts that come out.
    • Remove the filter button by pulling it out.
  4. Black and Decker BDH9600CHV Filter Button Replacement: step 4, image 1 of 1
    • Replace the new button by compressing the spring and placing it in the groove.
Ivette Muzquiz
349 Reputation
3 Guides authored
IUPUI, Team S1-G4, Harley Fall 2017 Member of IUPUI, Team S1-G4, Harley Fall 2017
IUPUI-HARLEY-F17S1G4
3 Members
3 Guides authored
One Comment
After a year of very light use, it was working great. Now I have been facing some troublesome it’s shutting down frequently as like after about a minute. I bought a new filter and it is still shut down. Kept on the charger all the time. Do you have any idea actually what is going wrong with it? Or do you have any suggestion which would be best for pet hair?
Alexis Martinovich - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 540
