Black and Decker Dustbuster CHV1510 Outer Shell Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Black and Decker Dustbuster CHV1510 Outer Shell Removal, Black and Decker Dustbuster CHV1510 Outer Shell Removal: step 1, image 1 of 2 Black and Decker Dustbuster CHV1510 Outer Shell Removal, Black and Decker Dustbuster CHV1510 Outer Shell Removal: step 1, image 2 of 2
    • Remove nozzle by pressing two blue buttons with unlock symbols on the side of the nozzle.
    • Pull the nozzle upward.
    • The other button cannot be seen on the image.
  2. Black and Decker Dustbuster CHV1510 Outer Shell Removal: step 2, image 1 of 1
    • Remove the six exterior 2 mm Phillips #1 screws that secure the two halves of the outer shell.
  3. Black and Decker Dustbuster CHV1510 Outer Shell Removal: step 3, image 1 of 2 Black and Decker Dustbuster CHV1510 Outer Shell Removal: step 3, image 2 of 2
    • Separate the two halves of the outer shell by pulling them apart.
  4. Black and Decker Dustbuster CHV1510 Outer Shell Removal: step 4, image 1 of 1
    • Remove the grey handle by lifting it towards yourself.
    • Be cognizant of the compressed spring in the handle assembly to prevent it from ejecting.
  5. Black and Decker Dustbuster CHV1510 Outer Shell Removal: step 5, image 1 of 1
    • Remove the switch assembly from inside the grey handle.
luke Gauvin
125 Reputation
1 Guide authored
One Comment
Well, 50mm thin screw driver is also one of tool, normally people don't have it. Hence special mention of philips screw driver might help user.
nestednloop - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 989
