Black and Decker BDERO100 Chassis Replacement
  1. Black and Decker BDERO100 Chassis Replacement, Chassis: step 1, image 1 of 2 Black and Decker BDERO100 Chassis Replacement, Chassis: step 1, image 2 of 2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Chassis Replacement: step 2, image 1 of 2 Black and Decker BDERO100 Chassis Replacement: step 2, image 2 of 2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Chassis Replacement: step 3, image 1 of 2 Black and Decker BDERO100 Chassis Replacement: step 3, image 2 of 2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Chassis Replacement: step 4, image 1 of 2 Black and Decker BDERO100 Chassis Replacement: step 4, image 2 of 2
    • Hold the chassis and separate it from the device.
Irene Zubillaga
617 Reputation
5 Guides authored
USF Tampa, Team 1-5, Sullivan Spring 2016 Member of USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 524
