Introduction
This guide will show you how to remove an inner tube from a bicycle tire. The process is the same for both front and rear wheels, even though this guide demonstrates the process on the rear wheel. While some components on your bicycle may be different than those shown here, the process will be the same.
Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
Slide the lever around the circumference of the wheel to completely remove the tire.
Or, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches along the rim. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third Work along the rim until the tire pops off.
Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
