This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
Following this guide, you will learn how to dismantle this hand-held blender and how you can replace one or both the switches. You will have to solder and work precise to be able to fix the product.
Take out the lower part of the blender, by rotating it clockwise, as stated on the upper part.
Loosen the two soldering connections between the metal connectivity ends of the switch and the printboard by heating it with a soldering iron from the soldering station (2), at a temperature of around 380 degrees Celsius. Use a desoldering pump (4) to suck the soldering tin away. Gently pull the switch away till it disconnects.
Take a look at this guide: How To Solder and Desolder Connections
If you followed all the steps, you should be able to use the product again.
Special thanks to these translators:
92%
These translators are helping us fix the world! Want to contribute?
Start translating ›
