Introduction
Projector lamp failure is most often due to failure with the bulb such as cracking or worse, the bulb exploding. Replacement lamps are more commonly found on the market, but naked projector bulbs are also available. Since upkeep with the lamp and bulb are necessary for producing the best image quality (not to mention safety), it is important to have these parts periodically checked and replaced. This guide shows how to properly replace the projector's bulb.
Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
Fully remove the top cover in order to get to the lamp housing.
Using a Philips #0 (PH0) screwdriver, remove the two screws holding the metal case of the lamp housing.
2 other people completed this guide.
3 Comments
Hey, Thanks for sharing the steps setting a Project Bulb Replacement.
we recently replaced Ht 1075 bulb after the main bulb broke. the projector runs for 10 min and them shuts off due to overheating. previously that was not the case. what could be the issue and how we can isolate and fix the issue..
From my experience try replacing the main blower fan located under the motherboard
