Introduction
Replacement for a Bell & Howell 16 mm film projector power cord.
Two standard screws on the bottom
  • Two standard screws on the bottom
New Battery = Faster iPhone
Fix Kits starting at $16.99
remove the four standard screws on each side
  • remove the four standard screws on each side
  • remove the nut from the toggle switch
  • loop the drive belt off the shutter wheel
  • lay the central armature to the side
  • You can either desolder/resolder connections or cap a new wire on. Either way, ensure you run the new cord through the base down the larger hole and up the smaller.
errolsayre
101 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 25
All Time: 260
