Battery Replacement for the VENSTAR Taco
  1. Battery Replacement for the VENSTAR Taco, VENSTAR Taco Disassembly: step 1, image 1 of 3 Battery Replacement for the VENSTAR Taco, VENSTAR Taco Disassembly: step 1, image 2 of 3 Battery Replacement for the VENSTAR Taco, VENSTAR Taco Disassembly: step 1, image 3 of 3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. Battery Replacement for the VENSTAR Taco: step 2, image 1 of 2 Battery Replacement for the VENSTAR Taco: step 2, image 2 of 2
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. Battery Replacement for the VENSTAR Taco: step 3, image 1 of 2 Battery Replacement for the VENSTAR Taco: step 3, image 2 of 2
    Tool used on this step:
    Phillips #0 Screwdriver
    $5.49
    Buy
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. Battery Replacement for the VENSTAR Taco: step 4, image 1 of 2 Battery Replacement for the VENSTAR Taco: step 4, image 2 of 2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. Battery Replacement for the VENSTAR Taco: step 5, image 1 of 2 Battery Replacement for the VENSTAR Taco: step 5, image 2 of 2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
  6. Battery Replacement for the VENSTAR Taco, Battery Replacement: step 6, image 1 of 1
    • A black fabric covers the ribbon retaining flap, remove it using the curved tweezers as it can be a fire hazard when soldering.
  7. Battery Replacement for the VENSTAR Taco: step 7, image 1 of 1
    • Remove the battery from the side of the casing.
  8. Battery Replacement for the VENSTAR Taco: step 8, image 1 of 1
    • Using a portable soldering iron, melt the solder on the red and black wires on the logic board. Be careful as you are working with the hot metal, it can burn you!
    • As an alternative to soldering, you can cut the red and black wires close to the battery and strip the ends. Then crimp the new battery's wires to the old wires on the board, making sure to match red to red and black to black.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 850
