This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
BOSCH MUM7000 replace torn belt
  1. BOSCH MUM7000 replace torn belt, Open the housing: step 1, image 1 of 2 BOSCH MUM7000 replace torn belt, Open the housing: step 1, image 2 of 2
    • Open 4 cross screws
    • Loosen some plastic latches
    • Simply "pull off" the knob while or before opening the housing
  2. BOSCH MUM7000 replace torn belt, divorce: step 2, image 1 of 2 BOSCH MUM7000 replace torn belt, divorce: step 2, image 2 of 2
    • Loosen screw
    • Turn back the plastic-tensioner so that the gear seperates from the rest
  3. BOSCH MUM7000 replace torn belt, Loosen belt: step 3, image 1 of 2 BOSCH MUM7000 replace torn belt, Loosen belt: step 3, image 2 of 2
    • Pull the black cap off the axle
    • Flip the longer belt over the pulley
    • Unscrew 3 screws to remove the plastic cover
  4. BOSCH MUM7000 replace torn belt, Remove belt: step 4, image 1 of 3 BOSCH MUM7000 replace torn belt, Remove belt: step 4, image 2 of 3 BOSCH MUM7000 replace torn belt, Remove belt: step 4, image 3 of 3
    • Lever out the clamps to remove the axle and take out the belts
    • Remove the clutch / gearbox
  5. BOSCH MUM7000 replace torn belt, Insert new belts: step 5, image 1 of 3 BOSCH MUM7000 replace torn belt, Insert new belts: step 5, image 2 of 3 BOSCH MUM7000 replace torn belt, Insert new belts: step 5, image 3 of 3
    • Insert new belts with the axle
    • Tension the 3M belts and reassemble everything
    • The rotation of the 5M belt determines the running direction! Do it as in the picture, so that this is correct.
Work through the steps in reverse order to reassemble your unit.
Special thanks to these translators:
de en
64%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Moritz Graf
277 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 753
