Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Bring life back to your Blu Life XL with a new battery. This guide instructs you to detach the rear panel assembly and replace the battery.
For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
  1. Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen. Remove the rear cover using your hands at the lip on the device back cover. No tools required. Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Remove the old battery. For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%. For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
    • Remove the old battery.
    • For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
James Whitlow
342 Reputation
3 Guides authored
USF Tampa, Team S2-G5, Eyestone Spring 2018 Member of USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 328
