Axess TA2513-10WT Side Button Replacement
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: step 1, image 1 of 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: step 2, image 1 of 3 Axess TA2513-10WT Side Button Replacement: step 2, image 2 of 3 Axess TA2513-10WT Side Button Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: step 3, image 1 of 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: step 4, image 1 of 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: step 5, image 1 of 2 Axess TA2513-10WT Side Button Replacement, Buttons: step 5, image 2 of 2
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: step 6, image 1 of 2 Axess TA2513-10WT Side Button Replacement: step 6, image 2 of 2
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: step 7, image 1 of 2 Axess TA2513-10WT Side Button Replacement: step 7, image 2 of 2
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: step 8, image 1 of 3 Axess TA2513-10WT Side Button Replacement: step 8, image 2 of 3 Axess TA2513-10WT Side Button Replacement: step 8, image 3 of 3
    • Remove the individual buttons with tweezers.
Lori Scott
101 Reputation
1 Guide authored
Baylor, Team 6-3, Shaver Spring 2015 Member of Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 221
