Introduction
This guide shows how to replace Axess SPBT1031 Subwoofer. Replacing the subwoofer is moderate difficulty and it'll take about 15 minutes to replace. Below is the step-by-step guide to replacing the subwoofer.
Look at the side of the speaker without the red interface plate; there will be a red ring around the mesh but no buttons on the side.
Remove the two 5.5 mm screws from the top and bottom of the black face plate using a Phillips #1 screwdriver.
To remove the the wires from the subwoofer terminals, use a soldering iron to reheat the solder at each of the four points of connection.
It's blowing my mind man, why is their 4 connecting points for the sub woofer WHY?
Tool used on this step:Desoldering Pump$3.99
Use a desoldering pump to remove the liquid solder from the terminals.
2 other people completed this guide.
One Comment
I Ned to replace the charger conection and I need the parts please u can email me at elpaleterolopez@Gmail.com or call me at 6613402547
