Introduction
The diverter valve may become clogged if water is not rinsed regularly with water after foaming. Or if the seals are old and need to be replaced. Sometimes the mechanics are loose and the sliding mechanism does not close properly anymore.
Tools
Parts
No parts required.
  1. The machine can be opened by a Phillips screw on the top
    • The machine can be opened by a Phillips screw on the top
    • Be sure to unplug the plug first!
  2. After opening the lid, the machine shows its interior.
    • After opening the lid, the machine shows its interior.
    • The water comes from the top right into the thermoblock and then enters the bottom right of the Themroblock in the switching valve.
    • Depending on the position of the milk frother nozzle, the water is either directed downwards into the frothing nozzle or to the left back into the thermoblock to the coffee spout.
    • Now, use the open-end wrench to free the diverter valve from all tubes and disconnect the hose.
    • Carefully disconnect the changeover valve from the milk froth nozzle.
    • If connections can not be easily solved, it is recommended to remove the complete unit consisting of thermoblock and diverter valve.
    • Remove 5 screws to remove the complete thermoblock and changeover valve unit.
    • Open the screws with an 8 nut.
    • Before the thermoblock can be removed, all cables and the temperature sensor are disconnected.
    • Note the removal of the cables well or note them down.
    • After that, the diverter valve can be disconnected from the thermoblock.
    • Possibly. Process calcifications with descaler.
    • In the interior of the valve, a small plug is pushed to the left and to the right to close the outlet on the right when the milk frother nozzle is unfolded.
    • So no more water can get to the coffee spout.
    • Thoroughly clean the valve and check the seals and replace if necessary.
    • When reassembling, make sure that the milk frothing nozzle is fully inserted, that the sliding mechanism works smoothly and that the nozzle is firmly connected to the valve.
Finish Line
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Matthias Mayer
232 Reputation
2 Guides authored
iFixit Member of iFixit
Community
108 Members
7,528 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 712
