Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
  1. Find a good spot to fit the pry bar between the back cover and tablet. Slowly drag the pry bar along the sides of the cover. NOTE: some force will need to be used to remove the cover. Avoid excessive force. NOTE: some force will need to be used to remove the cover. Avoid excessive force.
    • Find a good spot to fit the pry bar between the back cover and tablet. Slowly drag the pry bar along the sides of the cover.
    • NOTE: some force will need to be used to remove the cover. Avoid excessive force.
  2. Remove the speakers.
    • Remove the speakers.
  3. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  4. Remove any adhesives (such as tape).
    • Remove any adhesives (such as tape).
  5. Pry under the aluminum touch screen to remove the remaining components from the front housing. Pry under the aluminum touch screen to remove the remaining components from the front housing.
    • Pry under the aluminum touch screen to remove the remaining components from the front housing.
Logan
367 Reputation
3 Guides authored
Penn State, Team 2-42, Kaschak Winter 2015 Member of Penn State, Team 2-42, Kaschak Winter 2015
PSU-KASCHAK-W15S2G42
4 Members
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 278
