Audio Technica ATH-AD500 Left Headphone Cable Replacement
  1. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Speaker Assembly: step 1, image 1 of 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Left Headphone Cable Replacement: step 2, image 1 of 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Left Headphone Cable Replacement: step 3, image 1 of 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: step 4, image 1 of 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: step 4, image 2 of 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: step 4, image 3 of 3
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  5. Audio Technica ATH-AD500 Left Headphone Cable Replacement: step 5, image 1 of 2 Audio Technica ATH-AD500 Left Headphone Cable Replacement: step 5, image 2 of 2
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
  6. Audio Technica ATH-AD500 Left Headphone Cable Replacement: step 6, image 1 of 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement: step 6, image 2 of 3 Audio Technica ATH-AD500 Left Headphone Cable Replacement: step 6, image 3 of 3
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
Melanie Reis
227 Reputation
5 Guides authored
Cal Poly, Team 17-19, Forte Winter 2013 Member of Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Members
17 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 48
All Time: 9,641
