Introduction
This repair guide will help you with the following:
  • Install the left headphone cable
  • Fix sound coming from the left headphone
  1. Remove the ear pads by peeling them away from the grill.
    • Remove the ear pads by peeling them away from the grill.
    My jbl waerless headphone speaker changes how price
    Max Mad - Reply
    How to install the earpads
    rangaranju - Reply
  2. Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Remove the speaker from the grill by pulling it out.
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections. The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again. The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  5. Untie the knot in the thick main cable. Remove the main cable from the headphones by pulling it out.
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
    “Thread the replacement cable into the hole on the bottom of the headphones“ what replacement cables?
    John S - Reply
    Hey, read my comment on the bottom of the guide if it’s still relevant to you.
    Erez Dahan -
    I have the same question, what replacement cable do I need?
    Erez Dahan - Reply
  6. Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference How To Solder and Desolder Connections. The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again. The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
2 other people completed this guide.
Melanie Reis
146 Reputation
5 Guides authored
Cal Poly, Team 17-19, Forte Winter 2013 Member of Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Members
6 Guides authored
2 Comments
Thank you so much! your guide helped me repair my AD900x!
Anwar X - Reply
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
Erez Dahan - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 52
All Time: 7,460
