Introduction
Step by step tear-down and replacement of display assembly.
The original screen has the following code stamped on the back of the display: "TL055VDXP34-00".
The first replacement display assembly (did not work) had the following code: "TLD55VVXP31-00".
The second replacement assembly (did work) had the following code: "TL055VDXP34-00".
On that basis, I would suggest that the first unit I received was an earlier model, and was the incorrect part. I assume that the replacement display assembly must be model TL055VDXP34-00.
NOTE: Remember to remove the one next to the camera (this might be covered by a small sticker).
This cover should remove quite easily - if you can't lift it, count those screws! There should be 14. Again - check that one by the camera that is somewhat hidden.
NOTE These screws are actually the only screws which hold the phone together. Once these are out and the cover is up, the speaker unit will fall away from the phone.
For my phone (ASUS Zenphone 2 ZE500CL), I had to undo 18 screws in order to get the panel off.
To remove the plastic panel pry it up at one end, and use a sharp blade to separate the double sided tape between the battery and the plastic panel.
NOTE: I removed the double sided tape completely when I put it back together. It doesn't seem to really be necessary.
Remove the antenna cable, vibrate motor, and four other connections.
The three above the battery pop up away from the phone.
To disconnect the flat cable at the bottom of the battery you need to first remove the yellow plastic sticker covering it. Next lift the white tab to release the cable, then gently pull the cable out towards the base of the phone.
changed the screen and it works fine. But now the phone not recognize Sim card and SD card and vibration and sound does not work.
This is all part of the ribbon cable that sits on top of the battery. Check the connections at the top and bottom of the battery.
zacxzac -
I recommend heating the front side of the screen prior to completing this step (the battery tape is fixed behind the back of the screen).
The adhesive holding down the battery is located close to the side where the antennas are located (right side when looking down). To remove the battery, heat up the battery with a hair-dryer, then gently pull up away from the phone on the opposite site (left side).
That was the most difficult part to me.
The double sided tape is quite strong and was place on the right (the antenna cable side), so I had to lift the battery on the opposite side and then use a blade.
If you have the opportunity, you should separate the battery from the tape, I noticed that it was very easier than to separate the tape from the phone case.
There are actually two types of tape that I've encountered. One is easy to remove (double sided foam tape), and the other is very hard (some type of self amalgamating tape). I actually ruined the battery with the stronger tape. If I were doing it again I would recommend heating the screen before trying to remove the battery.
zacxzac -
For Asus Zenfone 2 ZE500C, the adhesive is on the left side (opposite side of the antenna), so it is easier to start lifting the battery from the right side. Also, there is another connector strip, going from top left to bottom left, glued onto the battery cage, which most be peeled off first.
Once the battery is out you need to lift the copper sheet from the body of the phone, which is held in place with some mild adhesive. Use tweezers and lift from one corner gently, working your way slowly across the square piece.
Lift the yellow plastic sticker, then disconnect the screen plug shown in the picture.
NOTE This is a connection for the display, and actually goes under the main unit in a right angle, then up and out a small slit at the top of the phone (shown in picture for step 17).
This cable is part of the display assembly, and is being replaced entirely. If it is easier, you could actually cut this cable completely.
I had some problem with This part , when i placed back the cable i didnt have touch screen fonctionnality anymore , when i removed that part i suspect it moved the connector , that seems to have some weak soldering or glue to hold it on the mother board, i found some guide that advice to remove the metal protection over the connector to properly disconnect it and reconnect after. that Seems safer to me, or maybe i was unlucky
I had to unplug then plug-in the display plug four times before the touch screen started working, I'm glad I tested it out before reassembling the rest of the parts. I don't know why it happened, but after inserting the SIM/SD cards it stopped responding again, I powered back down, checked the connections, reinserted the cards, powered up, and (thankfully) it was working. I finished assembly, and have power cycled several times and everything seems good so far, hopefully it was just a loose connection and now that it's closed up tight it will continue to work. If your touch screen doesn't respond, try seating the plug again.
There are four plastic retainers which fix the remaining unit to the body of the phone. Use a small amount of force on one side to pop this section out. Once this is freed, it should be simple to remove it completely.
Once the internal pieces of the phone are removed, you'll need to detach the display cable (from step 8) from the body. This is held in place with some adhesive, and shouldn't be too hard to pry up.
NOTE: Your new display assembly will have some adhesive on the replacement cable - should be self explanatory when fixing this back on.
To remove the display itself you'll need to apply heat. I had a heat gun - this makes it a lot easier ($20-$30 on eBay) but you could use a hair drier if you don't have a heat gun. For the sake of comparison - the heat gun took around 30 seconds to heat the display completely, which would take 3-5 minutes with a hair drier.
Once the adhesive behind the screen has been heated up, work your way around the edges of the screen with an opening pick or thin rigid guitar pick. The display will begin to separate from the housing.
Once mostly free, carefully lift the display cable through the hole in the top of the phone body. Again; you're replacing this cable completely, so don't worry too much about it.
You will need to separate the speaker grill from the original display, clean the adhesive off, and attach it for the new screen. I found it easier to attach the grill to the actual phone body (rather than the display assembly).
I think i have lost this speaker grill. Is it possible to find a replacement on internet?
Because of the condition of the adhesive for the screen assembly, I decided to replace the adhesive completely. You could skip this step, but I figured it was worth cleaning it up.
To remove the existing adhesive I just used the sharp razor blade and worked my way around peeling it all off.
NOTE: This would be a good opportunity to 'test fit' the new screen (without adhesive) so you can see where the cables need to go. There is one which goes up behind the screen and through the middle of the phone, and another which goes through the top hole. The top one is a strange shape, and needs to go through sideways first.
I’m new to this. What is the purpose of adhesive for the phone? What if i skip this step?
I used the 3M double sided adhesive tape to go around the edge of the new screen assembly.
NOTE: The replacement adhesive I used was 3M double sided adhesive tape (2mm) - the tape was around $10 from a mobile phone repair supplies store. The tape was too wide and not thick enough, so I doubled it over.
It fit perfectly once I did that. Unless you can find thicker double sided tape which is closer to the original adhesive, I would recommend this approach.
Once the adhesive is all laid out on the phone, put the screen assembly on. I started from the top and slide the top cable through the hole, then slowly worked my way down to the bottom.
NOTE: I'd suggest you don't press too hard on the adhesive until you are sure that both cables are through to the back, and that the screen is sitting well in the body.
Looking at the phone from the back, remove the adhesive backing from the display cable and carefully position the cable between the four black markers.
After the new screen is fixed in, start the re-assembly. This is effectively the same as disassembly, but in reverse. There were only a couple of parts that I'd make note of:
a) Keep an eye on the display cable that comes in through the top. Mine got caught on the double sided tape, and needed to be pulled through.
b) You will need to use a little bit of force to mount the processor unit between the four plastic clips. Be careful when doing this. (shown in step 10)
c) I completely removed the double sided tape from under the battery and under the plastic case. I figured that if I need to go back into the phone, I wouldn't want to deal with the tape again. I'm glad I did, because the first screen was a dud.
d) If you lose any of the yellow plastic cable stickers, you can borrow a piece from your old display assembly.
For an unknown reason, the phone didn't work at all at my first attempt.
Then I checked again the connectors to plug in back in step 5.
I removed the battery again in order to check all the connectors :
The one from the bottom is very easy to plug before putting back the battery in its place, because the cable must be push into the connector
In order to be sure not doing crappy thing, I suggest to unplug/plug the battery connector (I think it is the one on top right of the battery, near the antenna connection on top (it is writtent P+ and P- on the cable hidden side)
When I plugged in back this battery connector, the vibrator activated and the phone worked well.
what is the purpose of white sticker backside of zenfone 2
49 other people completed this guide.
45 Comments
hello where can I find the screen to ze 500 cl ? thank you.
Hi, the various Asus screens can be bought from aliexpress.com. They cost around US$20 each.
I would suggest checking eBay first, then Amazon. Plenty of them around.
zacxzac -
The only problem I have now is that the "wake on screen double tap" doesn't work anymore and I don't know why.
Guile~you should turn on 1.set>2.zenmotion>3.touch on>4.screen sleep>5.double tap wake up turn on
It might be worth opening the phone up and checking the connections - particularly the small connection shown in step 9.
zacxzac -
Hello, I'm with the very same issue: the double tap to wake does not work anymore after screen replacement. But the proximity sensor is OK. Did you fix it? If so, how? Thanks.
Здравствуйте. Есть ли чип bios на плате?
if you replace your screen and your touch input is not working, check the ribbon cable like shown here:
Hi! Where we can I get a display for ZE 500 CL?
Hello, please could you tell me this: My phone felt down and now the camera doesn't work (none of both), neither the flashlight and the notification led. I was searching how to repair it but I couldn't find the solution. Thank you in advance!
This is an excellent repair guide! Very well done! I have followed all steps and could successfully repair the display - the phone is like new!
Hairdryer works perfectly fine. Need need for a special heat-gun.
Some people were asking where they could order a display. I have ordered it from the following page:
Where is the proximity sensor? Is it soldered or connected by any cable?
I am asking because a shop replaced my screen, and now the proximity sensor is not working.
Thanks/
The proximity sensor is attached to the cable shown in step 9. You can open the phone up and check that this is plugged in properly. You only need to remove the back case & first cover.
zacxzac -
Actually the screw to the left of the camera has a "seal" sticker on it. If you remove the sticker probably the warranty voids. BUT if you have to just replace the speaker, then you can remove all the other screws (except the sealed one), and gently lift the bottom part of the plastic covering frame. That way you'll be able to easily extract the broken speaker unit and to replace it with a new one without voiding the warranty.
Hi, thanks for the tutorial. I replaced my screen with it, but I'm having a couple issues that I'd really appreciate your thoughts on.
The phone boots and acts like it's charging (orange LED turns on and when off, the charging animation displays), but the battery is stuck at 50%.
I had trouble with the battery's adhesive. I heated it with a hair dryer but it was still difficult. The adhesive was thick and white, like dried caulk. While wrestling with it, I slightly bent the battery. The foil didn't tear but it wrinkled.
In Settings > Battery, the battery level flatlined at 50%. Also, in Settings > About > Hardware Information, it lists Battery Version as "(null) ffffffff 000."
Lastly, in Settings > About > Status > SIM 1, Cellular Network State is "Disconnected," but I can make and receive calls and Bluetooth Address is "Unavailable."
What do you think is going on? Is my battery shot? If so, can you please advise where I can get a new OEM battery? Thanks again. I really appreciate your help.
Hi mate, try opening it up and checking the battery connection. I've had this issue before, and resolved it by making sure the connection was good. Should resolve the issue.
zacxzac -
I'm having problems with the touch screen. It started to be unresponsive some days after I replaced it, but it didn't notice it at the beginning because the problem wasn't serious. However, the following days it started to be always less responsive, and now the top part of the screen doesn't response at all. Inexplicably, sometimes the touch screen starts working perfectly for some minutes, and then becomes totally unresponsive.
Sounds to me like a loose connection. Open the phone up and double check everything that you connected, and ensure its seated fully. Worth taking your
zacxzac -
Hai this is harsha,i did the same thing the new display is working properly,but now the phone is not getting charged eventhough it is connected to the charger..so please let me know the cables attachment process for the charging port.??? please...
Everything went well except now my touch doesn't work
Hi, is there any possible way to bridge the connector that is at the very end of the digitizer? i mean the one that clicks on the motherboard... the thing is i dropped my phone on water, i did that thing with rice and i turned on perfectly after two days of drying... but the touch is now unresponsive, i checked everything and it seems that connector is like a little burned... so i was thinking like putting some metal or something above so it makes contact... thank you guys for any help...
the connector i am talking about is able to be seen on the second picture in step 9
Hi. Thanks for the instructions.
After I was done, everything worked except the proximity sensor seems to be reversed.
If I start a call, it immediately turns off the display without anything close to it.
If I then put my thumb over the sensor, the display turns back on.
Any ideas?
I'm already aware of how to turn off the proximity sensor in the Phone settings, but obviously
this is not ideal.
Hi yes I think I had this problem. From memory it was a loose ribbon cable in the back of the phone. I also had intermittent faults with my speaker and vibrate. I could not figure out why, and bought a better new phone!
zacxzac -
You are a pro ! Thanks allot!
Hi, I accidentally detached the digitizer ribbon socket from the Logic board... Would it be possible to reattach it?
Thanks!
Technically yes, but it's not easy.
zacxzac -
Step 9: This copper tape, is this Kapton tape? Can this be replaced with Kapton tape if one tears the original tape lifting it up?
Sorry not sure what it's called, but I believe you could replace it with a similar copper tape.
zacxzac -
Hi I replace the screen on my Zenpone 2 ZE551ML and the touch is not working. can you help me.
First check the cables under the back cover. If you're still having an issue, contact the seller - sometimes they sell faulty items, and usually just replace it no
zacxzac -
I replaced my display sucessfully, but I chose the display completly with frame. So the replacement is a little bit easier
Absolutely. That's the biggest thing I learnt from this repair - I only ever buy the whole replacement LCD assembly. It's usually only a little bit extra, and will save you a lot of heart ache.
zacxzac -
Excellent briko, very good work.
Following your guide I succesfully repaired my broken display.
My phone is now working like new, at the first attemp.
THANK YOU VERY MUCH!
Greetings! This January, I just recently took my ze551ml to the repair shop to replace it’s lcd/screen since it is crack and 80% of the screen is totally black and somethings flickering. After 2 months of usage the same problem occur and now the issue came back 80% of the screen is black again and sometimes it’s flickering when in Settings or other white background interface. Should I replace it again or there is other solution for my phone? Please kindly help me. :(
Well everything went swimmingly until I tried putting everything back together and noticed that the entire antenna connector came right off of the main board with the cable. Now I have no mobile data connection. So so close.
Where did you end up getting the screen assembly?
Aaron Zarn - Reply
www.aliexpress.com About US$20 each.
King Kong -
I got mine on eBay, but there are plenty of places to buy the screen.
zacxzac -
Can I use the same tutorial for the ASUS Zenfone GO ? ( with a compatible screen of course )
tpe.aeronautiquelucasetjules - Reply
