Asus Zenbook UX31E SSD Replacement
  1. Asus Zenbook UX31E SSD Replacement, Back Cover: step 1, image 1 of 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
    Can you tell me what size these screws are? I need to replace two.
    Elliot Lozano - Reply
    I don’t know, but you can search with product code: VISTORXUX31E
    See also: https://en.accessoires-asus.com/torx-scr...|l
    Davide Bortot -
  2. Asus Zenbook UX31E SSD Replacement: step 2, image 1 of 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E SSD Replacement, SSD: step 3, image 1 of 1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  4. Asus Zenbook UX31E SSD Replacement: step 4, image 1 of 2 Asus Zenbook UX31E SSD Replacement: step 4, image 2 of 2
    • Using your hand, pull the SSD out from its slot.
    domanda….come faccio a clonare il sistema operativo ?
    claudio_rava - Reply
    Questa è la guida per lo smontaggio, meglio se pubblichi La tua domanda nel forum, probabilmente se usi cerca troverai la risposta. Comunque ci sono vari modi e programmi per farlo, ma spiegarlo qui non sarebbe ne adatto ne pratico.
    Davide Bortot -
7 other people completed this guide.
Charles Jackson
668 Reputation
3 Guides authored
UW Tacoma, Team 1-2, Rose Winter 2017 Member of UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Members
9 Guides authored
One Comment
Vorrei fare una precisazione, l’SSD che monta questo laptop ha un attacco XM11, oramai non si usa più, pertanto è vero che possiamo sostituirlo ma dobbiamo aver cura di prendere un SSD M2 (2280) e un adattatore, io ho trovato su Amazon questo https://www.amazon.it/gp/product/B00XJRQ...
e ho preso come SSD un Crucial MX500 CT1000MX500SSD4 SSD Interno, 1 TB, 3D NAND, SATA, M.2 (2280)
Davide Bortot - Reply
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 52
All Time: 12,059
