Fix Your Stuff
Right to Repair
Store
Introduction
This guide is to replace the speakers on an Asus Xenbook UX303L Laptop should they stop functioning correctly. During replacement be careful not to pull on the wires too hard as well as be sure you have discharged any static electricity to prevent any static charge from damaging laptop components.
  1. Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Using your finger, gently lift upwards to remove the connection clip from the motherboard.
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Gently pull the speaker connection clip outwards to remove it.
    • Gently pull the speaker connection clip outwards to remove it.
  6. Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Carefully peel away the defective speakers from the battery.
    • Carefully peel away the defective speakers from the battery.
Ryan Snow
145 Reputation
1 Guide authored
IUPUI, Team S1-G6, Harley Spring 2019 Member of IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 Members
7 Guides authored
One Comment
Is the Asus UX303L same as U303L?
Michael Wolf - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 758
