Introduction
Replace the display in your Asus ZenFone 2 Laser 5" ZE550KL Model
Remove the back cover.
  • Remove the back cover.
  • Disconnect the battery.
  • Remove the SIM card and the micro SD card.
unscrew the 15 screws
  • unscrew the 15 screws
remove the plastic cap with opening picks making sure not to break the hooks that hold it in place remove the plastic cap with opening picks making sure not to break the hooks that hold it in place
  • remove the plastic cap with opening picks making sure not to break the hooks that hold it in place
disconnect the two lifts by lifting the white stopper unplug the camera unplug the camera
  • disconnect the two lifts by lifting the white stopper
  • unplug the camera
with the help of a spudger remove the rear speaker with the help of a spudger remove the rear speaker
  • with the help of a spudger remove the rear speaker
New Battery = Faster iPhone
Fix Kits starting at $16.99
starting from the bottom lift the motherboard starting from the bottom lift the motherboard starting from the bottom lift the motherboard
  • starting from the bottom lift the motherboard
Mother board. Mother board. Mother board.
  • Mother board.
disconnect the touchscreen driver to remove the screen disconnect the touchscreen driver to remove the screen disconnect the touchscreen driver to remove the screen
  • disconnect the touchscreen driver to remove the screen
with the help of a hair dryer or an iOpener remove the screen from the phone's frame with the help of a hair dryer or an iOpener remove the screen from the phone's frame with the help of a hair dryer or an iOpener remove the screen from the phone's frame
  • with the help of a hair dryer or an iOpener remove the screen from the phone's frame
Remove glue residues on the perimeter of the frame paste the display flat in position paste the display flat in position
  • Remove glue residues on the perimeter of the frame
  • paste the display flat in position
apply the double-sided adhesive to the frame apply the double-sided adhesive to the frame apply the double-sided adhesive to the frame
  • apply the double-sided adhesive to the frame
Replace or reposition the dust cover of the front camera before installing the new screen Insert the new screen into position by passing the flat into the specific grooves Insert the new screen into position by passing the flat into the specific grooves
  • Replace or reposition the dust cover of the front camera before installing the new screen
  • Insert the new screen into position by passing the flat into the specific grooves
Refit the logic board Refit the logic board Refit the logic board
  • Refit the logic board
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
gwsLabs
136 Reputation
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 117
All Time: 844
