Introduction
Wenn dein Computer beginnt, langsamer zu werden, öfter einfriert oder einen Blue Screen zeigt, ist vielleicht deine Festplatte defekt. Wenn sie noch nicht ganz kaputt ist, musst du ZUERST ein Backup machen, bevor du die Festplatte wechselst!
Entferne folgende Kreuzschlitzschrauben #0 vom unteren Gehäuse:
Sechs 9 mm Schrauben
Vier 11 mm Schrauben
Klappe die graue Lasche am weißen Anschluss mit einem Plastiköffnungswerkzeug hoch, um die Flachbandkabel zu lösen.
Schiebe vorsichtig die Flachbandkabel heraus.
Wenn ein Kabel festgeklebt ist, dann löse es vorsichtig von der Festplatte ab.
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
33 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
14 Comments
hi. i have the same laptop. the laptop bsod on me after i used it for a good 6 months. suddenly, when i start the laptop, it always boots me to the bios, the hard drive is change because i thought it is the problem (i just followed the solutions online which is a lot regarding the issue). my suspection is the hard drive connector to the motherboard pcb. is there any way i can replace with or where can i buy replacements for this same part? please help i really need the laptop for my school needs, and sorry for the bad english
I had the same problem. Sorry but its also too expensive to repair and the repair doesnt solve problem %100
AYG -
Im having the same issue. My HDD fails to start when my hand is over the hdd connector (just slight pressure). Any solutions?
ieg -
This is caused by the connection socket on the PCB between the little PCB that plugs into the HDD and the motherboard. Turns out that the great amount of flex in the (crappy) plastic body of these laptops causes too much strain on the socket (opening and closing the screen) and eventually the connector breaks. I had to order a replacement PCB on Ali-express.
Ettienne -
Great guide, thanks a lot. One thing to note, I found it wasn't necessary to remove the whole hard drive controller just to replace the HD. I was able to just remove the audio port board and then slide the drive away from the controller.
Thanks again!
