Introduction
This guide will show you how to remove and replace the trackpad. The trackpad is located inside the back panel and is fairly easy to replace if you are experiencing touch issues with the trackpad.
Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
The battery is attached by a set of wires.
Use your finger to disconnect the set of wires. It should come off very easily.
Unscrew the four 3.5mm screws with Phillips #00 Head.
This black plastic panel holds the trackpad in place.
