Introduction
This guide will show you how to replace the wireless adapter chip in your VivoBook.
Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center). Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
Use a plastic opening tool to pry the back panel off.
  • Use a plastic opening tool to pry the back panel off.
Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place. Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the ribbon cable with a pair of tweezers. Remove the ribbon cable with a pair of tweezers.
  • Remove the ribbon cable with a pair of tweezers.
Lift and remove the battery.
  • Lift and remove the battery.
Remove one 5mm screw using a PH0 Philips screwdriver. Remove one 5mm screw using a PH0 Philips screwdriver.
  • Remove one 5mm screw using a PH0 Philips screwdriver.
Remove the cable by lifting upwards with a pair of tweezers.
  • Remove the cable by lifting upwards with a pair of tweezers.
Remove the WLAN chip by pulling out parallel to the surface.
  • Remove the WLAN chip by pulling out parallel to the surface.
Bryann Tan
682 Reputation
6 Guides authored
USF Tampa, Team 16-2, Eyestone Fall 2016 Member of USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 50
