Introduction
If you find your screen unresponsive or visibly damaged, then you might need to replace your flip book LCD screen. This guide will illustrate how to safely remove your flip book LCD screen and replace it.
The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Gently remove the Wifi cables hooked to the rim of the battery
Remove the battery
Open your flip book so that the screen faces towards you. You will notice 2 rubber pads at the base of the screen.
Using a metal spudger, lift the rubber pads off to find 2 screen 3mm screws. Unscrew these 3mm screw with a phillips head J000 screwdriver.
After removing the screws, use the metal spudger to gentle pry open the screen casing from the flip book casing.
After all connections have been removed, use the metal spudger and pry the screen itself from the screen casing.
